Question on data storage
Rhino79
8
When I manually browse the files in My Files, I see that the directory is named /sdcard. But I don't have an SD card in my phone. Does the phone come with one as a "hard drive" so to speak? And if I upgrade its storage with an SD card, will I be replacing one?
Also, under Settings-Storage, it lists "USB Storage" and its values. What does this refer to?
Thanks.
I'm not totally sure but I think that internal memory is listed as /sdcard and if you have a memory card that is listed as /external_sd. I have no clue about the usb storage.
Why this is... I do not know.
/sdcard is a default "mount point" that points to an area of "internal" storage that as a user you can manipulate. Think of it as "My Documents". The rest of the internal storage is in different mount points that you can't get to - that helps prevent you from bricking your phone.
/sdcard/external_sd gets created when you insert an SD card into the slot in the phone.
/sdcard/usbStorage is empty unless you attach a USB storage device. When you do that, it gets mounted to the /sdcard/usbStorage "mount point"
These are, of course, my understandings only. Others may have different (more technically accurate) opinions. :-)
Your right on Mike. Its also listed in the Sticky "25 Reasons to buy a Galaxy S2".
958ryan
