Question screen saver
That is how mine is behaving. I wonder if this happened during the last update.
To tell you the truth I would of never noticed if I wasn't trying to help another poster looking for his issue found it by mistake . The only thing I can say is maybe enough people send the error feedback and Google will put a fix .
I got my pixel 3 one month ago. I still have the problem. Has anyone tried pixel 3 support at the bottom of the Settings page? They don't seem to answer that.
I don't think it's something that chat support will be much help with. I submitted feedback.
It's been my experience that regular support usually doesn't respond but Chat does. I haven't used chat for this problem because it's not a problem for me because I use the Clock as a screen saver and found no reason to change it. Good luck
I meant for this type of problem I doubt they can help. What support are you referring to? Chat is support.
I know of 2 support methods for pixel 3. Both are at the bottom of Settings screen. One is the standard method of feedback and the other is Chat. I don't get a response from feedback but I do with Chat.
You're not going to get a response from feedback
noroldie
