- Oct 30, 2011
- 39
- 2
- 0
To give you guys some background info, I bought this HTC EVO 3D pack on EBAY:
- Used HTC EVO 3D with default accessories
- Extra 1800 MAH Battery
- Platinum Series 2X Extended Life Lithium-Polymer Battery
- Invisible Shield - Smudge Proof - Anti Glare - Screen Protector
I also bought a Black Trident Aegis Case Cover (received positive reviews, couldn't find any negative ones...)
I still need a cover to use when I am using my "Platinum Series 2X Extended Life Lithium-Polymer Battery." Do you guys think the ACTIVE? Extended (by Seidio) would fit?
Also, how much difference is there between an 1800 MAH Battery and a 3500 MAH Battery? (I think the Double Extended battery is 3500) Would it really be twice as much usage time?
Thanks Guys!
Thanks Guys!
