Questions About Wireless Charging cover
MrMLK
631
Does anyone know any of the details related to the wireless charging cover? Does it add a lot of thickness? Will it still work if the phone is in a slim case? What is it supposed to cost?
Thanks.
Yes it adds a little thickness. but not much. A friend of mine has it for his S4. It add a slight thickness.
Yes it adds a little thickness. but not much. A friend of mine has it for his S4. It add a slit thickness.
Thanks for the info. DOes he keep his phone in a case? If so, does he need a non standard case, or will it still squeeze in?
No he does not use cases. But I think it can still use an case if he wanted to. I do not know if the case would interfere with the charging.
Good question about cases and the wireless charging. I was always told that it added enough bulk to make the standard cases not fit properly so I simply skipped over that feature. I would like to have it, but not if I can't fit it into a regular case.
I bought the same product for the S4. The back is thick enough that the camera lens is now recessed slightly. That's great if you want to protect the camera but not good if you use a hard case. I used a poorly fitting bumper, some others used TPU cases.
You can look on the xda developers site, S4 accessories, wireless charging & find more info about the issues for this with S4. I'm hoping the Note 3 wireless charging back is thinner.
You can also get the qi charging slip and just attach it between the battery and the back cover. Im sure it makes the stock cover stick out though as with the gs4. I just looked on ebay, dont see any listed for the n3 yet, just the n2, gs3 and gs4.
Mobilefun.com has them as well. Its their US site. They also say the wireless charging S View cases should be in around 1-2 weeks. Im holding out for that.
Found one for the note 3
nic12345
