Quick Question: My 6p battery is it normal?
Jul 21, 2016
3
Please just quick answer: Is this normal? used 10% battery in 30 mins.
Info: I play game(Robbery bob, not heavy graphic, not light graphic) with my 6p, used 10% battery in 30 mins.
(40% bright, 20% loud, no wifi,no data,no bluetooth,no location) Thanks a lot in advance.
(I can't really answer because o don't own a nexus 6p but a nexus 4,
for 30 minutes screen on time, playing a game, and 10% battery = 1% per 3 minutes,
in my opinion i think that is decent/normal,
after all it's a super big QHD display + snapdragon)
Thanks a lot Fericire. Your reply is really big relief to me.
However I need more person to give me more reply as this answer. So Pleaseeeeee.
You're on pace for 5 hours screen on time, which is definitely solid
Yes.
*6P 64 gb Graphite (AT&T)*
*iPad Air 2 64 gb Space Gray (AT&T)*
Try not using it for an hour or longer to see if you have any wake lock draining issues?
Seems about normal, if not slightly bad
Ashok Dharshan
