funkylogik
- May 21, 2012
- 9,631
- 111
- 0
Try WidgetLocker. Yeah it's a Paid App but it makes your Lock Screen as customizable as any other screen in your phone. Worth the $ IMO.
Oh, and it also supports global Badge Notifications (not just SMS / GMail / Missed Calls)
Can you install Widget Locker without rooting? I.e. Is it an app that you install and just put a checkbox next to an option for global badge notifications?
I've been reading that you need to use it with Missed It / Nova Launcher, etc.
Thanks. You gave me the motivation I needed to actually get it...
Definitely. And I downloaded the nova notifications one. Is missed it better?...
think il give widget locker a try. can u change style of clock etc?..
Using "Missed It!" you can get Badge Notifications for every single one of your Apps installed on your phone if you like (and select which ones do / don't display it), not just SMS / GMail / Missed Calls...
...il try+find it for free ...
...i cant seem to add more than two shortcuts or actions (i add them in the editor but they dont actualy add) any ideas?
You need to click "Done" after you've edited it.
Click to view quoted image
