QuickPic and Evernote gone from multi window tray
Redbirdsfan70
Prior to a couple of days ago and about a week after the OTA update I had both QuickPic and Evernote in my multi window tray. Now, they aren't there anymore. Has anyone else had this happen or can anyone explain it? I do believe both apps updated recently but I can't see anything on their app sites in the Play Store indicating this has changed. I also do not believe there is a way to get them back there without rooting the phone, correct? Any help would be greatly appreciated. Thanks!
What Scott said, but before you do that, make sure they are not just sitting in the Edit holding area, the place where you drag multiwindow apps that you don't residing on the multiwindow launch bar. Typically, you would have to move them there yourself, but you never know with these updates.
Sent from my GT-N8013 using Android Central Forums
Darn...why didn't I think of that simple solution. Thanks! It worked. My frustration with this tiny issue is over. :-)
Glad that worked out (it was just a hunch since I haven't had first hand experience with apps moving there "on their own"). Now that I know that can happen I'll watch out for it myself.
Sent from my GT-N5110 using AC Forums mobile app
ecomranx07
