radio problems?
ajbrad71
272
14
18
Had my m8 next to a co workers m8 he had full bars and I was roaming. My internet seems to drop alot and so does my calls. I'm on Sprint and they are doing work where I live. But there shouldn't be that big of a difference in signal.
I've been having multiple problems with my radio, on sprint. I am roaming in many areas I used to have 3g and when I am connected to 3g it still does not have a data connection.
Posted via the One successor to the One
The only thing i can think of is to go into settings and see if you both have the same PRL info.
With it being on sprint that can make a difference.
Since your actually getting signal it shows your receiver is working. With it showing roaming that might be more of a programming or provisioning issue.
dmflowsjalallodhi
