RAZR ICS Question?
OK man. Sorry. Although you can't say how close to the front it is until it gets it.
Sent from my DROID RAZR using Tapatalk
Setting aside the best buy rumor there have been leaked builds for both the Razr and Rezound. It is a virtual certainty that they will be the first ones to get it. Which one will be first depends on which one gets a release quality build submitted and through TA (Technical Acceptance) first. At this point you will have to be satisfied with either first or second place. Other than that it is impossible to be certain.
rosannejoy555
