- Mar 9, 2012
- 169,105
- 10,288
- 113
No, I am having the same exact problem as Mickkev. I can connect to Wi-fi at home but at work it says I am connected with excellent signal strength but I cannot google
or fb or anything. It says retry. I even had Verizon try to walk me through. I am in dire need of a fix for this problem.
Welcome to Android Central! Does your work wifi have a login webpage, or is it only a password right when you choose the network? If there's a login webpage, make sure you open your browser first to access that page. You might have to type in a URL like Google or Yahoo first, in order to trigger the login webpage to pop up.
It would be ideal to try rebooting the work router, if you can. Is it easily accessible, or is it hidden somewhere? To reboot the router, just unplug the power, wait 10 seconds, then plug it back in again. You might have to ask your IT department to reboot it for you.
