Real ICS rom for DX?
Thanks for the link for the keyboard. It's extremely fast and as good as Smart Keyboard without of all the additional options.
Sent from my DROIDX using Tapatalk
Yup same for me to the dx will go in the sock drawer once the nexus is released.
sent via TaPaTaLk
It's the .apk of itself. Once you have it saved to your SD card, just go into your SD and select it.
Then go into Settings System Language and Input Settings
Also make sure, do the same in your sms app settings.
Do you know if there is a shortcut to bring up the number pad like in swype?
In swype you could draw a line from the option key to the 'f' key.
It seems that i can only get it to come up on gb or ics kb if the selected field is expecting numbers only.
Yea the button on the lower left corner ?123 brings up the numbers.
This is the one I'm hoping to find a shortcut for. I can only get it to come up when the input field is expecting numbers only such as entering a phone number in a new contact. There are many more times I'd rather have this KB pop up instead of the symbol KB.
Not sure on that. The keyboard commands are in control there. It relates to the action you are performing.
The update for the Defy build is online(download server is out though) at Galwaynet. That could be flashed onto our Xs right? Its the stock android modified version unlike the MIUI/ICS build. Thoughts?
Alternatively if you want a pretty full featured ics rom encounters over at rootzwiki is pretty awesome. I will edit a link in after work.
rvrsco
