Really would like to hear about battery life & signal strength!
Re: Really would like to hear about battery life & signal strengt
my phone was charged fully charged at 9am today, went to eat and gym then came back and it was at 20% without using it. i just changed to cdma so hopefully it works. if not i have to exchange it :(
also it seems that i have like 30 apps running at once.. i dled advanced task killer and i kill all apps, 5 automatically reappear and then within 10 minutes the rest come back on even if i dont touch my phone.. any ideas? im coming from BB so im kinda lost with droid but catching on quickly.
Nope that is absolutely normal....ah, no I'm joking. LOL Either your phone didn't charge last night, or there is a serious problem with it. Try to charge it once more, see if it holds a charge, and if it doesn't, then take it back.
I had it plugged in with the EXTENDED BATTERY this morning at work.. said it was all the way charged and ready to be unplugged. I unplugged it and after about an hour i was already down to 80% with 1 3 minute phone call, 20 texts, a few IMs on Google Talk and that's it. I have it set to CDMA and no Wifi or GPS and my display is pretty dim.
I am thinking device problem. I might exchange for the Droid Charge I hear the battery is better on that and LTE might come to my area sooner than later...
Thoughts??
Glad I am not the only one that had drain like that.
I also thank you for the tip about CDMA and not using Global. I don't travel overseas so I don't need it set to that. I will see if that helps my issues.
I woke up this morning and didn't touch my phone until 15 minutes off the charger and it was down to 40% .... so either I have a bad device or bad battery or this was causing problems.
Not trying to sound daft here, but did you have the USB connector fully pushed in? I noticed the first time I plugged it in that if you aren't paying attention, it can feel like it seated even when it is only half pushed in.
-Suntan
Mine was properly inserted and said it was fully charged during the morning and early this morning when I woke up. So I know it was in correctly.
** UNINSTALL THE TASK KILLER *** They are the bane of Android and not needed in any version of Android after 2.1. Android will manage the free memory and kill un-needed tasks when memory is needed. Those apps restarted again in the background because they were designed to. This isn't a Blackberry and just because the app shows as running does not mean it is actually using any CPU cycles, but every time it restarts itself again DOES use battery.
EDIT: If you are running a Windows computer hit CTRL+Alt+Del and open the task manager and start killing processes and see what it does.
good to know bout the task killer. i switched to cdma when i posted earlier and ive only lost 20% like 12 hours later.. so that definitely helps.. lets see how it does on a full charge and full day use tomorrow.
So Gingerbreak 1.2 does not work on this device. Truthfully wasn't expecting it too. There was that chance...
Once this animal is rooted and we are able to remove/freeze bloat, the battery life of this thing will be even more amazing
just curious, what is the cell standby and phone idle percentage for battery use supposed to be? mine are 44 and 36 for 12 hours. i compared it to my buddies DX2 and his was way lower and he had better battery life. i tried *228 to reprogram the phone but it wasnt too helpful.
I have about 70% of full charge after 14 hours of use.
I probably don't use it the usual way, though - I have G3 turned off by default, I only turn it on when I need to check my email, surf, remote in to the office, etc. As long as I get calls and texts at all times (which I do with G3 off), I'm fine.
My battery life has been about as good as my Blackberry (which was very good). However, I do have Juice Defender turned up to to the more aggressive level.
Signal strength has been great.
Well I took the plunge and picked up a Droid 3 today, so far so good. Too soon to really predict battery life as most of the first day it has been installing apps and syncing data so it's obviously using more data (and battery life) than a normal day. I like what I am seeing so far.
It is noticeably bigger than the D2G but not in a bad way feels more bulky/solid than the D2G but not quite as much as the original Droid. Battery door feels flimsy like a HTC device.
The version of Motoblur installed does NOT have the "scenes" (that's HTC's term, I know but not sure what else to call it) that the leaked version of the Droid Pro has. Hope to see an upgrade at some point because I really like it. Keyboard is just plain AWESOME. Not quite as good as my old Ally keyboard but WAY better than anything else I am seeing.
"Keyboard is just plain AWESOME. Not quite as good as my old Ally keyboard"
Haha What? :eek: Sorry, but this kybd blows away the LG Ally. Hell even the Env Touch kybd blew away the LG Ally. :D
The Voyager, enV Touch and the LG Ally have almost exactly the same keyboard (very minor differences). LG makes great keyboards, with Moto would take a lesson from them....
Must agree with cthunder, but it is all in personal preference that matters.
Sent from my DROID3 using Tapatalk
Was having terrible battery life since I got the phone on Saturday (switched to CDMA only immediately). Yesterday afternoon I uninstalled Widget Locker and did *228 and my battery life improved noticeably...but still not great.. not as good as my Dinc2 even. Unplugged at 0530 this morning and I am now at 90% (its 0900 now) with no phone calls, no texts and only light surfing.
Cell standby - 32%
Phone idle - 27%
Display - 3%
Better than yesterday...sucks tho...I was really digging Widget Locker.
Update -- So after 15 1/2 hours, i am at 40%.
Something has to be up with mine. After a full charge a minute after I take it off it drops down to 90%. Then at midnight still at 90% but when I woke up at 7 it was completly dead.
Cell standby- 38%
phone idle- 37%
Well I finally bit the bullet! After 10 months of sitting on the fence with my $100 new every two credit, I went to Verizon and with the BOYO, I bought myself and my wife each a brand new Droid 3 all for $100.
Sweet deal!
Anyways, I'm new to android and so is my wife. We are now divorced from BB and have a 14 day engagement before tying the knot!
I've been reading many posts and do understand that I will not get the battery life with the D3 as I did with my BB 8330. So to help with this, I'm compiling a list of things that needs to be done in order to save the precious battery. I came across this post and have a few questions. Here they are.
Are you talking about the Task Manager or an app called Task Killer? I you mean Task Manager, how do you uninstall it? If you are talking about an app called Task Killer, my question would then be: Is it automatically installed and how do I remove it.
Thanks for your help!
Sweet deal!
Sounds like you got a sweet deal. I myself got mine for $149.99 at a corporate discount (no NE2 or rebate).
Anyway to answer your question. Any and all task killers are completely unnecessary on any version of Android 2.1 and later. The reason is that Android manages the tasks by themselves. It will kill things it does not need and just because something is showing as running in the background does not mean they are actually using memory and in fact killing those processes generally gets them to start up again because they are meant to be running thus using memory.
On very rare occasions you may get a rogue task eating up your memory and in almost all cases this is cured by force closing the app (Settings > Applications > Application Management) or worst case scenario is you reboot the phone or remove the offending app.
Task killers (apps the show a list of running tasks and let you select what ones you want to kill and may or may not have a white-list) are evil. People come to Android from a non smartphone or from a Blackberry (or the old Windows Mobile) and are paranoid abut running tasks. Many uninformed store reps will even install them for customers or offer to because the customer complains about the less then stellar battery life the first couple days.
One thing that people need to get out of their head is that these things have anything remotely to do with other phones. Android phones are COMPUTERS plain and simple and like all computers they are very complex and learn over time how to work more efficiently and manage memory.
Task MANAGERS (apps designed to kill one task at a time) are slightly less evil but just as unnecessary as Android has those tools built onto the OS. Why are they so burred? Because they are not meant to be used regularly. Built in task managers should just be ignored and only used when absolutely necessary.
The best tips I can give you when it comes to memory management are:
1. Stop worrying about tasks
2. Decrease screen brightness when not needed. I don't recommend doing so to the degree that it decreases your enjoyment of the phone but it does not always need to be at a high setting. The screen on the D3 does not use nearly as much memory as say the Thunderbolt or Charge but it's still something to consider.
3. Decrease the time-frame of your data syncs unless you NEED instant updates. If you are just at work or otherwise occupied you can manually sync your data as needed.
4. Minimize the number of widgets you have on your home screen to the minimum you really need. Facebook for Android (of FriendCaster) may be cool but remember it is constantly pulling data from Facebook.
