Recommend a magsafe car charger and case for my S24 Ultra.
Laura Knotek
Moderator Captain
Moderator
Jan 8, 2011
13,752
9,914
113
For those of you who have a magsafe car charger and magsafe case for your S24 Ultra, which do you have that works well? I want to mount it on the vent in my car. I'll need a case and charger that are compatible together. I prefer something from Amazon.
I can recommend this case.
CaseBorne Slim Series Compatible with Samsung Galaxy S24 Ultra Case - [3-in-1 Combo] [Ultra Clear Hybrid Magnetic Cover] with Tempered Glass Screen Protector https://a.co/d/5p2Ox6F
I don't have a MagSafe car charger, just a MagSafe car mount.
Reactions: Laura Knotek
Thanks. I'm not interested in screen protectors, though.
This case is the one I got. It's really a great case! It's the 360 spin by Torras and not only can you use it for mag safe, but it can be used as a kickstand in just about every orientation as it spins 360 degrees. It's high quality materials.
Hello Laura, I got 2 cases with magsafe and like them both one is a CaseBorne (ArmadilloTek) and a Torras (see pictures).
The Torras is a tiny bit thinner and I think looks great if you have the gray GS24 Ultra, the bad thing though, it's that the case is too slippery and the O ring isn't 360° spin.
Anyway, I just recently got a Lisen car holder charger (fast charge) that attaches to a car's vent, and so far its been working great (see pictures below), it holds my GS24U easily with either case and it hasn't fall off in any of the normal driving conditions I've had in the last week.
Sent From the TARDIS20240309_102917.jpg20240309_103003.jpg20240309_103018.jpg
Dang it, I forgot the pictures of the 2 cases with magsafe, here you go.
By the way, I have used ArmadilloTek cases for a long time now, and they are great, and this is the first time I get a Torras.20240302_211038.jpg20240302_194827.jpg
By the way, I have used ArmadilloTek cases for a long time now, and they are great, and this is the first time I get a Torras.View attachment 360744View attachment 360745
Yeah. I have the Casebourne MagSafe case too. That works well with all of my wireless charges.
How does that UPRO case work with non-MagSafe wireless chargers? The Spigen clear with MagSafe doesn't work with Samsung Duo wireless charger.
You mean the CaseBorne tough case?
It works fine if I remember correctly, I'll try it again tomorrow with all my wireless chargers and post my findings.
Sent From the TARDISView attachment 360760
I have both Caseborne Clear with MagSafe and the Armadillo. I meant the other MagSafe one.
This one.
Tfunz
