Recommendation for a tempered glass? (using a spigen tough armor)
  • Start date Start date
A
Android Central Question
I'm having trouble deciding on a tempered glass for my galaxy note 8.
Would anyone who has a spigen tough armor case recommend a good tempered glass that doesn't affect the phones touch sensitivity? This has been an issue for me for other glasses I've purchased.
Would really appreciate it.
I moved this to the Note8 Accessories forum for more specific traffic.
I am using the Whitestone Dome protector with the tough armour case. It is tight but it fits.
I have officially given up on Glass Screen Protectors for my Note 8. I can't seem to find one that has no issues with screen use. I bought an IQ Shield (wet install) protector from Amazon and installed it yesterday. It's crystal clear and works great!!! Super easy to install and was ready to use right away.
I'm using Zagg. I had a one-by-one inch area of rainbow-effect in certain bright lights, but now surprisingly after two months, seems to have essentially gone away, which is good.
This is where I am. For such a cheap solution, wet film protectors can reliably be installed by anyone, and produce a result that is quite good, although not perfect.
I do hold out some hope that a reliable and affordable glass solution may emerge on the market.
I'm sick of my Zagg glas protector so I think I'll go this route, as well. Question, though: any idea what the difference is between the Case Friendly IQ Shield and an Case Friendly, Version 2? Which did you get?
TechWeave
