Recovery Boot Loop
Check your pm box I set you up with the exact links and instuctions you just need a fresh thunde rom.zip to flash and you be on your way hope that helps ya
Ya I sent him to eather or lol how did the epic go for ya did you happen to use odin or just went the way it was?
ok. I tried pushing recovery 1.2 but it says file not found. i placed it on the root of my sdcard then disabled usb, went into adb shell and when i typed adb push recovery-thunderc-s-RA-v1.2-GNM.img /sdcard/ it says file not found
i followed the how to guide for restoring to stock rom but still boots into recovery. i have thunde recovery 1.1 already installed and everytime i tried pushing thunderc v1.2 it says no such file or directory, any suggestions?
Smccloud Ya thats cool was there something sever wrong with it ? And kweezy I might have not put the command for pushing the file right go to the link smccloud posted and use those commands but you have to change the name of the file to match just like the one on the post but with v1.2 name the spaces and / marks might be messed up from me deleting the old version and slaping the new name there sorry
i have an sprint optimus s android 2.1 and it continues to show the lg screen i did a factory reset and now i cant get back into my phone.
please help
please help
I read that once you have a custom recovery installed on your phone, factory reset will do this. Search this forum for the issue, others have had it and I believe have recovered from it.
Check It Out
please help
Read through the forum thread that you can find here. There are ways to fix this, just read through it and follow the directions exactly as posted.
Good Luck.
Sexygirlsse
