[RECOVERY] Clockworkmod for EVGA Tegra Note 7
mattlgroff
3
Do not use this to install an Over-The-Air update from EVGA/Nvidia. Use the stock recovery for that.
Do not use this on any Tegra Note 7 besides the one by EVGA. Other variants are untested.
Download: CWM for Tegra Note 7
Instructions:
Code:
fastboot flash recovery tegranote-cwm.img
Bugs:
Upside down graphics (PS: The recovery isn't upside down, you're just holding it wrong :-$)
No external SD-card or USB OTG support.
Does NOT backup BOOT.IMG, RECOVERY.IMG, or STAGING.
Source (Device Tree): Device Tree for Tegra Note 7 CWM
Source (CWM): Github for CM11 Android_bootable_recovery
Source (Kernel): Ask NVIDIA! It's a stock kernel from the 4.3 firmware.
Changes I made into CWM are included as attachments if you want them (rename recovery.c.txt to recovery.c and place in /bootable/recovery/) (copy icon_clockwork.png into /bootable/recovery/res/images/). Too lazy to fork and link a new CWM folder. I swapped the Volume Keys Up and Down because this one is still upside down. Doesn't seem to be a good way to go about flipping it without breaking things.
  • recovery.c.txt
    recovery.c.txt
Re: [RECOVERY] Clockworkmod for Tegra Note 7
Thanks a lot for sharing!
cinemacritic
