Recovery mode for 4.3!? Please help.
Nuuq
357
I updated my rooted nexus 7 to 4.3 but all apps now says that I am not rooted!? And when I try I can't go to recovery mode (used to have clockwork mode), I only get 'no contest' msg... How can i get back my clockwork mode??? Please. Need my titanium backup and tegrra prism.
Thanks in advance...
Used nexus toolkit to go back from PA to stock rom than OTA 4.3.
You have to reroot your nexus 7. Use a custom recovery and flash Chainfire's SuperSU to regain root.
Go to www.chainfire.eu on your device and download it from there. Then use a custom recovery to flash it.
Congratulations. You are now rooted.
Sent from my Nexus 4 using Tapatalk 4 Beta
Any guidance how to do that? So far, I used toolkit.
But i do not have custom recovery...
Ofc, but how to install it. Really my knowledge of rooting stops at simple toolkit (noob, almost).
Then now is the time to learn how to use fastboot, unless the toolkit you are using can auto flash a custom recovery...
My bootloader is unlocked. As far as I know I need that. Now I need to install recovery (would like clockwork mode cause i used it before) but have no clue how to do that. Cant find guide on google.
Nexus toolkit 5.smth. On first step when i need to choose software theres only 4.2.2
Live long and prosper.
You can just wait for the toolkits to be updated. Wugfresh is supposed to get updated today.
