Regular battery swappers, preferred case?
Snoflo
5
Hi everyone,
I'm in a bit of a quandary: I swap batteries almost daily on the Note 4 but I would like to keep the phone in a protective case as well. The Caseology one I have is a bit of a nightmare to remove and I have suspicions that the case scratches the metal rim on the phone too.
Can anyone suggest a phone case for frequent battery swappers? Or is going naked the best way (which is what I do now)? Thanks folks.
I prefer the Otterbox Defender cases. (I wouldn't drive over one, but it feels as if it should almost take it.) I've dropped my phone a few times now, and the case has saved it.
But it is a royal pain to remove it to change the battery - which I only do monthly.
I haven't found any really solid case that's easy to use if you change the battery. (And going naked isn't something I want to do unless absolutely necessary. Even my cheap spare phone is in a belt pouch that's worth about as much as the phone.)
I use an otterbox symmetry and swap batteries daily. It's real easy takes >1min to swap. The symmetry protection seems good to me. I've dropped the phone a few times from waist high with no problems.
Posted via Galaxy Note 4
Wonderful! I will check both of these options out. Thanks much.
piikea
