Replace Stock Sprint/ANDROID poweron boot animation/sound
You need to edit thunderc_keypad.kl its in /system/usr/keylayout/ keys 139 and 102 need to be switched just use es file explorer it has all you need to do it
Tapatalk'n it from my VM670 running LS670ZVJ Dante Rom
Reactions: eller200
Thanks works great :D
Only problem is, I don't see the time at the status bar
A minor bug in the rom.. You need to go into cyanogenmod settings-interface-status bar tweaks and change the clock color
Reactions: eller200
Okay, I'm able to do everything and do the boot animation, just one thing, I want to remove the Inferior Human Organs unofficial logo splash in the beginning, anyway to do so?
Unfortunately there's not an easy way to change that... There is a way that I read about but I never did it
Reactions: eller200
Ahhh I'll read up on it, also I'm trying to get Smart Keyboard Pro as the keyboard. But when I enable it on the Language And Keyboard Settings, I click on the enable box, which gave me a notice that "This input method may be able to collect all the text you type..... Use this input method?" I click ok and then went out of the settings and back into it and automatically un-box the enable box, so I tried to click the enable box on it again. And then no help. It won't enable, I tried to do this with Swype Beta to, I get the same results.
That's strange never had an issue like that or heard of anyone else with the issue. I may have to flash backside to see if I can reproduce it.... Hmm... Or if you want make a nandroid backup and try on a fresh install of it.
I already went ahead and made a make up a few minutes ago, I tested with, I think there is something wrong in my data. Because when I restored factory settings through the recovery and then installed the keyboard, it stayed active. I really don't want to reset it. I restored my backup. Is there away around having to do my phone all over again? Something I could clear the data off of an app. Perhaps pertaining to the keyboard areas.
Try uninstall and reinstall the keyboard...... I don't really know another way.... Use titanium backup or a similar app don't backup app data do a clean install and restore via titanium?
I decided to actually not deleted and go through the log process over again I re-installed the phone with the same rom it was used to make. Acting as a update, but I had to re fix some settings though I didn't have to restart on the apps. Which I was happy with. Though I did seem to lose the home key, but I did edit the file in the keylayout.
Actually I just checked and for some reason even a complete reset of the phone, I installed the swype keyboard and another one, and for some reason when restarting the phone, it disables the keyboards. So this is a error in the rom
Must be specific to that keyboard then.... I always used SwiftKey when I was running it
Sent from my VM670 using Tapatalk 2
geochapman
