Replaced Note 3 charging port, and now my screen won't turn on
fisherri
5
I replaced the charging port on my Note 3 today; easy peesy, but not my screen won't turn on. The phone powers on, but nothing on the screen. It is such a simple procedure; I don't understand what could have happened. I haven't put the screws back in yet; but in the video, he checked his before putting them back in, and it came on just fine, so it doesn't haven anything to do with that. I'm at a loss!!
Well, you had to do something wrong or it would be working.
Double check all connections.
(Not as easy peesy as it seemed, huh?)
I figured it out for future reference for anyone else... I had accidentally loosened the LCD wire. ?????? very happy now!!
I figured it out for future reference for anyone else... I had accidentally loosened the LCD wire. 😃 very happy now!!
I just had the same problem happen to me just now. Where exactly is the LCD wire located in relation to the layout of the Note 3 back panel?
alyssadrysdale
