- Jan 2, 2010
- 60
- 0
- 6
I'd like to get another charging/data cable for the Nook Color. I've tried random USB A to microUSB cables without luck. The B&N site specifically states that we're supposed to use a special cable. Apparently this is because of the 200mAh charging "requiement" vs. the 500mAh USB stadard.
From the PC Mag review:
Some users report that generic MicroUSB cables will trickle-charge the Nook Color as long as the screen and WiFi are off. :-/
Has anyone found a replacement cable that works for fast charging? The B&N web site shows this product as out of stock. None of the local stores have one.
Turns out the cable that comes with the Nook Color has a few extra pins in it, to enable faster charging. The custom connector supports 2000mAh charging, whereas most mobile electronics use 500mAh chargers. This is limiting, since it significantly reduces your charging options, but it isn't much different than the proprietary charger that's required with the iPad.
