I saw there is a way to side load the theme. Is that what you did?
I found that the screen sensitivity reduced drastically after a couple weeks use for the note7 (original and replacement). I'm sure the s7 edge would be the same. Too bad it didn't work out for you.I don't like the 7edge. It's too curved. Ran hot. Screen too sensitive. I had it for 12 days while waiting on replacement. Not for me.
Then 2nd issues... Note5... Like it
It's ok, little Schlubbe, your note 7 is just going to go live on a farm where it can run and play all day.
Love how two different comments in the thread say 'it isn't lesser' and then include the word 'minus' in the next sentence. A $50 isn't lesser than a $100 - it's the same thing, minus a ten and a couple twenties.
Obviously, I ordered it, and I'll be doing the swap - whole point of the thread is just that I really don't wanna (like the rest of you, I'd guess).
I got the theme. Are you rooted or did you figure a way to get package Disabler to work. Theme resets after a short period since the update. Thanks
Not rooted,use package disabler .apply theme,then kill these programs![]()
You have to clear data when you click on those items. Not just check the boxesAhh....I missed the second one... Thanks
Darn.... It reset even with those killed. I think the n7 got an update that disables this from what I read?
I just can't used to the curved screen. My palm always hits it and causes issues. Was gonna get a s7e but opted for the v20 instead. If I could get the injustice Batman s7e..... I would go for that for sure!
Yes, Injustice looks pretty slick. Personally, I believe the Olympic version (can't believe it's been two months already) seems a gem too with its presentation case.
Yes, i saw a video on it! I think there is an iron man galaxy too. Might he older version?
My Co-Worker received her replacement N7 then the return box for the old N7 came a week later. She then received an email that confirmed they received her first N7 back! She is like what do I do with the extra phone, every one at work said together "keep it". lol
She's probably not going to be able to use it much longer...why keep it?
