Reports on 5.1.1 update for S6 edge T-Mobile
Yea I've recently picked up the edge and I love the phone but damn it has some serious lag to it. You can clearly tell the memory isn't handling the apps properly.
They are doing that for the Memory Leak issue on the S6 variants. I have 2 devices (Edge in my case) just configure you Google Account and the device uses 86% of the 3GB of RAM available. Other issues are battery and Wi-Fi stability. So they need to do that or sales for the S6 versions wil crash hardly.
Anyone that wants the Smart Switch PC app for Reflashing factory ROM, backup and restore, here is the link. Is from Samsung UK since was not found on the USA website.
SAMSUNG's Digital World
Your link gives me a file called Smart_Switch_PC.exe which is 37.1 MB
The following link which is from the US Samsung site :
Samsung Smart Switch™
I click on Smart switch for PC and get SmartSwitch_2.3.14044_3.exe which is 8.2 MB
Unless the one on the US autodownloads the full version which gives me the same as the one on the UK, not sure why the size difference.
I guess I should be able to use either on with no difficulty correct?
kothakisu
