Restart Loop issues - hard reset not working
V3rn0n
Hi,
When I switch the phone on and before the phone goes into andriod software, it restarts in a continues loop of restarting.
I have done a hard reset, but after (the hard reset) it restarts, and it still loops into restarting.
Any ideas on how to fix this?
Boot the device into recovery mode and clear the cache partition. Try a reboot and see if that fixes your bootloop. If not, then go back into recovery and select factory reset/clear data – this should fix your problem. If not, then there is an underlying issue. I would suggest starting with the battery and replacing that. If that doesn’t fix the problem then there is likely something else wrong with the hardware/software, and a replacement or repair may be the only options.
Welcome to the forums. I would contact LG. There was a bootloop issue with the G4, and it's possible there might have been an issue with the G3 as well.
Michael4444
