Review: Seidio Active Combo Case for the MoPho
sjamie
Grand Tech
Mar 29, 2011
491
14
I've been using Seidio's cases for a long time. I feel like the company is almost a part of my family. My relationship with Seidio started with my old Sprint Instinct. I simply loved the build quality of their Surface Combo case. This case was actually better than the phone! :p
After a year of waiting for promised updates that never came, I moved on to the Palm Pre. Although Seidio's Surface Combo case for the Pre was sexy, the build quality was less desirable. The tabs which held the case in place constantly broke off due to the Pre's svelte design.
Due to my Pre experience, when I upgraded to the EVO 3D, I approached Seidio's Active Combo case with caution. Fortunately, my faith in Seidio was fully restored due to the OUTSTANDING build quality of this case. I could not find ANYTHING wrong with the Active Combo case for the 3VO.
When I upgraded to the beloved MoPho as an earlier adopter, I was disappointed to discover Seidio hadn't released a case for it yet. This phone is too hot to have it walking around naked; therefore, I picked up the Sprint Holster and Shield Combo to tide me over. Although, I was pleased with this case, it definitely was not a "Seidio". Once Seidio released the Active Combo case for the MoPho, I couldn't wait for it to arrive at my doorsteps. As soon as I received it, I ripped open the box and installed my trusted armor for my MoPho.
attachment.php
attachment.php
Here are my thoughts on the Active Combo case for the MoPho.
Pros:
  1. Solid build quality of all 3 components (skeleton, rubber case, belt clip)
  2. Perfectly aligned cut outs
  3. Little added bulk
  4. Easy to remove
Cons:
  1. Easily attracts lint (minor)
  2. The biggest issue is top of the belt clip is naturally positioned to unintentionally slip *under* the top edge of the Active Case. It should be angled differently to easily go *over* the top edge without having to use two hands to place the MoPho in the belt clip.
attachment.php
attachment.php
attachment.php
attachment.php
Overall, I give this combo case a "9" (out of 10). It would be a solid "10" if the belt clip was slightly modified to allow the phone to be placed in the clip without having to manually lift the top part of the clip (usually with the other hand) over the phone. Even with this annoying problem, I strongly recommend this case!
attachment.php
attachment.php
See more pics below!
Reactions: Kbrn and Beknatok
Direct link where you bought it from? I was looking into an otterbox. Also, is the back smooth without the belt clip attachment? I would prefer it without it.
Sent from my MB855 using Tapatalk
So you'd say its as good as otterbox for protection? Heard some bad things about photons dropping.
edit: Also in the pic from top view, it shows it adds a black button like to the power button, does that make it easier to press the power button? Or am I imagining that being there, I always felt the power button was too small.
Thanks for the review on this. Think I'll pick one up in the morning.
Well, if you need super-duper protection because you are a construction worker or something then go with the Otterbox Defender. That thing is built like a tank and it turns your phone into one too! :D
Yes, this Active case adds a black rubber cover over the power button which makes it much easier to press. You'll love it!
Purchased, amazon prime free 2 day shippin...love amazon. I'll reply back here when I get it.
So I got it today. Put it on in less than 5 seconds. I like it mostly because of the rubber casings over all the buttons. The black outer shell seems to get a bit heated but it could just be my imagination especially since I'm not playing a game or not watching a video. No complaints, all holes are visible and accessible. Just curious how it'll hold up if it fell on its face. overall, good purchase.
Edit: yep, heat was in my head, removed case and all was well.
gocoronago2021
