Rezound ext. Bat. Door...
BOBD1950
8
OEM extended battery door. WANT TO BUY.
Have the ex battery,,already
Hard to find​
Here is my issue with the extended batteries. THeir size, I have one on my t-bolt and it would be nice to buy a belt clip or case that would fit the extended battery to keep the phone safer.
you can get the shell holster combo that can work like a belt clip. i would only recommend using it in vertical mode though, as horizontal can cause it to fall out.
Set Your Location
Bought mine from eBay. Already had the battery from my Tbolt which does fit.
Sent from my ADR6425LVW using Tapatalk
panelexchange
