Rezound OTA Update Incoming!
I tried the screen off trick. I turned it off then ran the update check again. It found the update again and started downloading. After downloading the update screen came up and I hit OK. This disappeared and nothing after that....
If you go into;
Settings > Software Update > Check New
You'll find what you seek, adventurer.
Try to restart again
If you go into;
It didn't work, at least for me. After downloading the update, I tried going there to install it, but got nothing.
If you temp-rooted and debloated the phone you have to re-bloat it before the OTA update will stick. Be warned the Zerg Rush temp root method seems to not work after OTA (at least it now fails for me) so you will get the updated ROM but at the expense of now having to see all that crap in your app drawer.
Yeah, this has been discussed before, there is no temp root options as of now post update, but hopefully there will be something soon.
I rarely use the app drawer, i set up folders and put it on my desktop for the more frequently used apps.
I did not want to get the update, but I figured that since I got the phone for $50 on upgrade, i might also well update to see if there are any issues since I am still within the 90 day return period. Note that different sellers may have different return periods.
My device is unlocked, perm rooted, and I've got CleanROM installed (and LOVE it)...this update will screw it up, won't it? My update has already downloaded, but I deferred the installation. Is there anyway to get rid of it completely so I can just stick with CleanROM?
I done the update, now speedtest app wont run. Only change I see is that when I go to task manager, the bar that showed how much I was using use to be red, now its green. So is my toggle widget, use to be red, now green. I dont have a battery indicator or anything different.
Can't really skip - mine just launched right into the update, I was never asked, just looked up and the phone was installing the update. Which is why I came to the forum to see what the update was all about, so thanks.
Rattljazz
Try to uninstall and reinstall the app.
Anyway to force the update? I just got a new Rezound and it's not showing any updates. I have done the check new the last 3-4 hours
Hi All,
New the forum stuff, The new OTA has failed to install on my Rezound. Was wondering if there was a way to get it to work without having to reload all nloat and relock phone.
Thanks
E
My update came in this morning at 5 am. At first it was posted a cannot update on the phone due to lack of battery life. I got up at 6 and quickly backup everything. I then swapped out my battery hoping that I would be able to apply the update when I was ready. It was already applied and just needed the reboot. I cannot see any major changes. WiFi still works....
I'm in the same boat as you. Not sure whats going to happen...I'm gonna take it over the to ROMs section and see if I can get an answer.
Wanda, there is a way to hack some xml file or something that tricks the phone into thinking it has already applied the update. Not sure the exact procedure, but I read about it once.
Also, the damn thing installed last night at 5am without my permission. This totally pisses me off. I do NOT want verizon/htc installing **** on my phone without my permission or knowledge.
Ota today. Don't realy see any thing new. Looks like its usingore RAM in the task manger... One question... Why Verizon?
This is nothing new it always happens eventually.
Gizka
