Rezound will not switch from 1xevdo to lte on active connection
dpham00
Moderator Team VP
Moderator
Apr 23, 2011
30,106
203
63
Well, my Rezound will sometimes switch to 1xevdo especially after loss of signal, but I noticed that it will not switch back to lte on an active connection. For example, tune-in radio always runs data. I can leave it for hours on tune-in radio, and it will not switch to lte, but as soon as i turn off tune-in radio, it switches to lte right away. I am assuming that this is the way it's supposed to be?
Re: Rezound will not switch from 1xevdo to lte on active connecti
Probably. That sounds like a built in mechanism to prevent data interruptions. Can you tell if the status bar is simply reporting 1X and you're actually on 3/4G or are you truly still on 1X?
1xevdo is considered 3G technology. It will show 3G when connected to 1xevdo.
You might be confusing 1xevdo with 1xrtt?
Yadatis
