Ringtone keeps resetting
I had the same issue (T-Mobile) with my 1st Note 7. The ringtones I downloaded were from Zedge. Seems to be working fine now with my replacement. I would suggest removing the SD card and then reinserting it (powering off the phone of course before doing so). Hope this helps.
Problem is I never downloaded ringtones or put them on a SD card.
I'm simply using the ones that came with the phone.
It's not the best answer, but it works for now.
I started using Tasker to set my ringtone. I already have profiles set up for charging and discharging, so I added setting the default ringtone to both of these. Now my ringtone sets itself to the tone I want several times a day.
Yea gotta be something else, don't think we would need an app to use our ringtones that came on the phone lol.
That's not a bad idea. I've never used tasker before, how difficult is it to set up something like that?
There is a little bit of a learning curve, but once you get the hang of it, you will find a lot of uses for it. In the case of the ringtone, I just added it in as the last step on a task that fires when the phone starts charging and the same for another task that fires when the phone starts discharging.
direct
