Roaming
jralabate
Android Ninja
Apr 26, 2011
124
12
18
I know we can't do off network roaming but if I go out of state can I still use VM if there is sprint there?
Sent via Tapatalk using a LG Optumis V with IHO(all) CM7
I used to live in AZ. I believe Virgin only works in the Continental US, Hawaii, Puerto Rico and the US Virgin Islands. You can use wifi outside the country.
Sent from my VM670 using Tapatalk
I'm outside of VM service, but the people I'm with have Sprint and have full signal. So, unless it shows on VM's coverage map, you're not going to get service.
The common misconception here is that you'll get service where ever someone who has Sprint has service, but the truth is Sprint phones can roam off Sprint's network, so they'll have coverage outside Sprint's network. If you're on VM, you're limited to the Sprint network only, no roaming.
If you go outside their network, you can still use Wifi to get data, but if you want to talk on the phone you're stuck using something like GrooVeIP over Wifi.
Ok cool thats wut i wanted to know. cuz i will be on the road soon going to all of the lower 48 states.
ksothpaw9
