[ROM][5.07.2011][ED01]Community Rom V1.3
To me, I think it is worth the flash to stock. But for some, they don't want too.
And I do not know much about voltage control and kernels at all....can you give me a suggestion of what you think is the best setting?
I was chatting with someone about it. Leave everything alone up top, so leave in "sio" and limit clock to 1000mhz. than with all of the settings keep in mind some peoples phones can underclock more than others. the person told me to start with all the 1000mhz and under so (1000,900,800,600,400,200,100) Make them all -50 to start with and see how it goes, if good than go lower if lagging than raise it up to -25 or to that effect. than soft settings key after all -50 where i said and do "apply for now" if working well for a day or so than do "save as boot settings" hope that helps guys. Shark that should help us start for now. If you need more clarification let me know.
The data wipe in between steps is what messed you up. Try powering down phone, flash EC01 radio, close ODIN, pull usb cord, reopen ODIN, attach usb cable, flash cwm 3-30, close ODIN, pull usb, put battery back in, hold 3 buttons to boot directly to cwm, wipe cache and dalvik only, flash community rom, enable lag fix before rebooting, reboot.
Ahh, thanks! Sorry if you've posted the link before, but where can I find just the EC01 radio?
What theme's can I use with this rom? I tried Nitro honeycomb and I get FC's
Did you flash the theme in a separate cwm session from flashing the ROM? Did you wipe cache and dalvik before flashing theme? Make sure of those two things. Flash rom, reboot and let ROM fully load, boot to cwm, wipe cache and dalvik, flash theme, reboot.
I have not done anything with voltage control either, so we will all be learning as we go. Check out nemesis2all's kernel thread over at XDA, it will have the standard suggested voltage settings, and numerous people have posted the voltage settings that have worked for them.
keep an eye on this thread for reference
Share Your Nemesis2all's Kernel Settings - xda-developers
it takes a lot of trial and error, but it's awesomely customizable:D
also, remember to try and only use 5-7 states, and only "apply for now" until you get exactly what you want and stable, then you can "apply on boot"
Yes this does help a lot.
thank you very much.
Thanks to everyone involved on this one! DEV's here are amazing!
I had gone dormit flashing my phone but I feel a awakening of some sort taking place...YUP, file is dling now.
Of course this drops the day I have to work until midnight...
On break run into nearest coffee shop/internet Cafe borrow some dudes laptop that is making believe he is working to try and pick up chicks while he drinks an overpriced latte, download and hopefully have a spare USB nearby.
...dude will probably be using a MAC anyway
or just fake sick
:D:D:D:D:D:D
or just fake sick
:D:D:D:D:D:D
lol I will just load it up in the morning
Sharky when this all gets cooled down we need to play with that voltage, i know ur hella busy now, did u see what i posted a few pages back? I started messing with it so should have a jump on it. Kev you r missing out...did i just hear you coughing? you better go home sick and rest......
I finally got the nerve to get cm7 this morning.....loved it but came right back for this! Thanx everyone involved. works great.
This is the first custom ROM that I have seen that I really really want! No offense to all the devs out there... I may have to try this out! can always go back if I don't like it, right?
wokulbo1
