ARCHIVED: [ROM][ALPHA] quattrimus ICS
Status
Not open for further replies.
Re: [ROM][ALPHA] quattrimus CM9 (ICS)
Uhh bleh
How do I upgrade from an older version?
Do I need to do a Factory Reset/Dalvik and Cache Wipe?
Thanks tdm! I appreciate you feeding my addiction. :) Now I just gotta still get my homework done... :(
There are two instances of the gallery app.
EDIT: As well as two different versions of Search.
Reactions: tdm
Uhh bleh
it's always proper to do a full wipe. But if you want to do a dirty flash, it's your phone. Worst that can happen is you'll get FCs and be forced to wipe. And don't submit bug reports on a dirty flash please.
New CM9 build is up, check the OP for details.
Sorry no AOKP yet. Between fixing CM9 issues and updating my AOKP source tree, I just ran out of time. I'll try to get it released tomorrow.
Changes:
* Synced with CM9 as of today. root is now an option in the developer prefs.
* New gapps.
* New adreno libs.
* OpenGL rendering in the UI is enabled.
* apps are automagically relocated to sd-ext (see below).
* More aggressive file removal. gapps went on a diet, let me know if market works.
* bootlogo and chargerlogo are functional. Booting with USB cable will hang at chargerlogo.
* email timeouts are reduced.
* Probably some other things.
The boot scripts require an empty /data/app to use /sd-ext/app so your existing apps don't get hidden. If you do a full wipe, this Just Works. If not, you really should. But move your apps to /sd-ext/app, then reboot for it to take effect.
Oh, almost forgot .. I have all the extra packages in a zip (DSPManager, live wallpapers, etc.) I'll post those tomorrow.
Would you please update the first post? This will get harder to find as more people post.
Thanks, as usual, for your hardwork. I greatly appreciate it!
For wifi i heard u got to reboot twice, and idk if that don't work go turn airplane mode on and of/data and then it'll probably work
Changes:
* New gapps.
* New adreno libs.
Thanks for the post.
Ok tdm i found a bug. Music playback does not work via bluetooth at all. It plays fine through the handsets external speaker but as soon as i turn on the bluuetooth it just starts skipping from track to track. and no audio comes out at all.
Reactions: tdm
I see both searches but only one gallery... Did I miss it? Duplicates are likely from gapps, I'll try to sort those out.
Status
oval_clarity
