[ROM] Android Open Kang Project
Did b37 have the new boot ani? Its awesome!
It had the pink background with the unicorn swirling around I think
Sent from my Galaxy Nexus by way of Tapatalk
Is anyone else having a problem with Rom Control force closing when you try to update your weather?
Edit: Never mind, did a wipe and did a clean flash and no problems now.
Flash b38 B-)
Ok so I am going to run you through what my mind was saying after i read this:
First I was like oooOOoo!! b38 out finally!
Went to aokp site. Then I was like "awh no b38 yet he trolled me :("
Suddenly a wild file site link appeared! :O
I click on it and view to see that b38 is indeed out on the file share just hasnt been updated on site yet :D!
Downloaded and saved to computer
Tomorrow will profit.
Change log is out for B38:
B38 Change log:
reverted tablet nav bar button padding change (back to stock ics padding now)
fix SMS/BT crash bug when no msgs exist
reworked lockscreen music layout to be cleaner
fix ugly gradient on dark holo background
added AOKP Tips widget
added statusbar autohide for tablets (for apps that need full screen)
added support for more lockscreen targets (2-8 options, your choice)
cleaned up octo lockscreen layout
fixed certain FCs with RC related to weather
Mms: fixed stripping certain Polish characters
decreased size of custom lockscreen apps to match other icons
statusbar brightness enabled by default after you wipe (sliding thumb across statusbar to change brightness)
added statusbar notification counter (RC > Statusbar General > Notification Counter)
new AOKP boot animation from @rascarlo
Out of range Bluetooth devices won't show up anymore in Settings
Browser: added option to close all other tabs (besides current)
Fixed data toggle
Removed requirement to reboot when toggling keyboard switcher (IME switcher) in statusbar
added nav bar widgets (to enable, go to nav bar settings > add toggle widgets as one of your nav bar actions/ long press actions, then add widgets -- be sure to add at least 2 for best experience)
as always, tons of fixes for devices and other backend fixes!
Is it just me or is the latest version of Franco Kernel Updater messing with my galaxy nexus. The screen gets incredibly dim with the latest version.
I have not noticed that....
check it out... The latest version was just updated a couple of hours ago. And I just installed B38 clean. After the Franco Kernel updater updated and I restarted my phone, after it gets into the lock screen, the screen goes super dim.
It's the franco app. I had the same issue - very dim purple. Uninstalled the app then reinstalled it, now it is fine.
Did you dirty flash or should there be a wipe involved?
Im really excited about this one, nav bar widgets look awesome.
I'm thinking I'm gonna dirty flash this one, dont really wanna go through the hassle of setup again, even if it only takes an hour.
You should be fine, however do all of your backups as usual first.
dang just downloaded 37 day before yesterday haventflashed it yet was going to today... lol guess il just delete and get 38.. :)
Not having that issue yet (knocking on wood) did you do a full wipe?
Any glaring issues with B38? I'm still on M5 (to my understanding, those are the "stable" releases, and the Bxx releases are potentially more likely to be buggy?), considering flashing to B38 for those navbar widgets... Or should I just wait until M6 releases (whenever that may be)?
Not that I can tell.
oval_clarity
