[ROM][AOSP][10/31][JB] Bugless Beast VZW Galaxy Nexus
where did you see a modified power menu? i did the update but everything seems the same
Hold down the power button should look like this now.
So the gapps are included in the Rom ?
This new nightly seems like it's killing the bat. The Jan 5 version was much better
Edit: This is the extended battery
I agree I killed a extended and standard yesterday about 6 hours on each. Might flash back. Not going to carry 3 batteries.
Yeah, that is my extended battery there
Re: [ROM] Bugless Beast for Verizon Galaxy Nexus Updated - 1/8/20
I always notice crappier battery life for the first 3 days after flashing a new update. It seems to level out after that.
Re: [ROM] Bugless Beast for Verizon Galaxy Nexus Updated - 1/10/2
How is the 1/10/2012 update? Did he fix the battery drain?
yeah the 1/8/12 update killed my battery had to charge it at 11am and i unplugged it from the wall at 7am
Flashed it seems good now to beat on the battery.
It's still a battery killer. I need to switch until the issue is fixed.
Mines been ok for a first install, 70% after 4.5 hrs...usually it takes a day or two to settle.
I didn't see any issues with the last one either though.
Sent from my Transformer Prime TF201 using Tapatalk
Make sure you fully change the battery then boot recovery and wipe battery stats. Should be more accurate. I made a quick backup of the new bugless and jumped on the codename rom. So far its nice.
Sent from my GalaxyNexus using Tapatalk
I'm with you on this..
both 1/08 and 1/10 drained about 15% IDLING per hour after boot/full batt, no fbook, WWF, plume, syncing.. nothing
CPU hasn't been in deep sleep for a second, on either 1/08 and 1/10 for the last 24 hrs :(
Same here
Sent from my Galaxy Nexus...maybe...depends if the network is down again
Reading through the official BB thread over at RootzWiki it does look like there's an issue with deep sleep in 1/8 and 1/10 causing some battery drain.
Going back to 1/5 seems to correct it.
I'm sure it'll be fixed soon. Keep in mind, these are nightlies but Pete does release stable versions of the ROM for folks that need/want something more reliable.
Just a reminder, this isn't a support thread so if you do have problems, the best place to go is the official thread linked below. Pete is good about addressing issues so I trust he'll correct this one if it proves to be a problem but he's stated that the only place he's monitoring for is the official thread.
I only posted and maintain this one to give people a place to discuss the ROM and stay up to speed on updates.
Official Support Thread
Reactions: jpbass7
Qbaumildand
