[ROM][AOSP][10/31][JB] Bugless Beast VZW Galaxy Nexus
Re: [ROM][AOSP][9/7][JB] Bugless Beast VZW Galaxy Nexus
I'm installing this ROM for the first time, coming from Euroskank, so I know I need to do a full wipe. from reading through the last few pages of this thread, I'm a little confused as to whether I need to also flash a separate gapps, or are all the gapps already in the main toro download?
You do not need to flash a gapps package because it is already included in the ROM
Appreciate it!
I did a more thorough search and found quite a few people asking the same (probably due to so many ROMs keeping them separate these days). Maybe digitalslacker could add a note about that to the OP?
Appreciate it!
Will do!
Cleaned up the OP with a few more FAQs and now some install instructions. If anyone has any changes or suggestions let me know!
flashed the 9/7 build last night and it's silky, but the wallet app didn't work right out if the gate. I have never, prior to this rom, even attempted to get wallet on my Toro but it was a main reason for flashing this rom... any ideas?
What error are you getting? Did you happen to restore the wallet app with tibu when you flashed bugless... That'll break things
never had wallet to begin with so nothing to wipe as far as that is concerned. when I open wallet it simply says that this version of wallet is no longer supported and kicks me to the play store where, naturally, I am not allowed an update.
ah ok
I'm getting the same thing now, i guess they are doing a version check when you open wallet and the version in Bugless doesn't make the cut.
You'll need to either load the new one yourself or wait until Pete updates Bugless with the newer version.
That's a Google thing, not related to Bugless and it sucks that we can't just update from the Store, but whatever...
Sucks because I have $15 to spend on prepaid cards before i lose it!
first full (half, really) day with BB and it is pwning my battery! I know there are options such as flashing different kernels, but that's not something i've ever attempted. I'm assuming it works exactly like flashing anything else (push, install from cwm, be on my merry way) but do i need to do this in a certain sequence? Like, say, before flashing the ROM itself? Any suggestions on which kernel to go with?
In the OP is a FAQ and i talk about the battery life there.
1) just backing up installing the ROM will destroy your battery because it's CPU intensive.
2) it takes a few charge cycles to recalibrate your battery usage.
I'd fully charge it...and watch it over a few days. It should improve.
EDIT: The install instructions on the OP also talk about the order you need to do things in. ROM, then kernel.
excellent...I will check that info out. Will I find anything in there related to the wiping of battery stats? that is something else I know nothing about but figure I probably need to get familiar with. Thanks in advance!
Per Google, wiping batt stats does nothing but erase the history saved for how apps use the battery. It does nothing for battery life. They stated that about 10 mos ago.
Does everyone recommend sticking with the stock kernel in BB? Or is there a general consensus kernel that people flash that works well with BB?
Thanks in advance
Thanks in advance
The stock kernel is great and its what the dev recommends. That being said, Franco's kernel is great and I love it on the gnex.
My battery life is atrocious since going to 9/7 with their kernel. 16% drain in less than an hr with full signal (4g) previous version I used from July was much better.
If this doesn't improve and I go back to Franco I am flashing the Pink Unicorn.
how long have you been on BB? my first day was a quick one in terms of battery life, and it has gotten a bit better, but I'm still interested in trying a different kernel. With that said, can anyone point me to some sort of general kernel FAQ or something? I get the basics of it all, but am lost when trying to decide/decipher the cpu/gpu speeds and whatnot.
It can take a few days to see real battery life after flashing. Just flashing backing up and flashing the new version will suck your battery down. That process is CPU intensive, the screen is always on and you don't have the bits in the OS helping to improve battery life because it's not loaded. Once the flash is complete it can take a few charge cycles for things to settle down. The type of drain you are seeing doesn't surprise me. Give it a day and see if you see an improvement.
This is a pretty good explanation How to Get Better Battery Life and Performance on Your Android Phone with a New Kernel
What you are talking about with the CPU and GPU speeds is basically governors and over/underclocking.
GPU: is the graphics processing unit. Dedicated CPU to push pixels, basically. In the case of the GNex, there seem to be two speeds, 384MHz, default, and 512MHz. I'm sure there are other speed options out there but those are the most popular that I've seen.
Like any type of overclocking, your specific phone MAY not be able to handle 512 well. You also aren't going to see higher battery drain on 512MHz vs 384MHz, for obvious reasons. I'm not one to dwell on battery life. I don't believe that i should sacrifice a phone's features or speed just to get an hour or so more battery life in a day. But, I don't run 512Mhz because it does seem to kill the battery pretty fast and aside from gaming, which I don't do the phone, there doesn't seem to be any real benefit to me so I just stick with 384MHz.
CPU: With the CPU and kernels it gets more complicated. Most custom kernels will support some over/under clocking but the max and min varies for a number of reasons. There are also cpu "steps". This is the speeds that the CPU increments up and down at, like the steps on stairs and includes the various voltages that each of those steps operates at. Generally speaking, I don't screw with those. I don't even overclock. The way I look at it, someone smarter than me set that all up and thinks it's right, and I don't know enough to disagree, so I just leave it at the defaults.
Governors: How the kernel spins up and down. Meaning, when and what happens to make it go up the "steps" and then back down. This is pretty complicated. There are about a doz different governors out there and most are based on other ones and there are new ones that pop up every few months, some stick around, others fizzle out. I don't focus too much on the names because honestly, their implementation between kernels can be different anyway.
Generally speaking, considering what I've said above, I like Franco's 384MHz, running on his balanced profile which runs at 1228MHz on the CPU and uses the Interactive governor.
Now, with all that said, I don't use a custom kernel for all the stuff above, really. I use it because a good kernel dev merges in drivers and changes from a ton of different sources (like the new WiFi drives in r251) and implements kernel features that aren't in stock (Color and sound hacks are two of my favorites in Franco's).
Hope that helps a bit! Mostly I just felt like babbling for a bit :)
Has anyone been able to get NFL Live to work on BB ?
FCed more than a few times but apparently worked itself out for me. had trouble getting redzone to play initially.
handsome
