[ROM]BAMF 2.4.1|2.11.605.0| (Side Project)
Adrynalyne
Account Deactivated
Dec 24, 2009
1,346
1,534
BAMF 2.4.1
This is a side project that I was doing because I had some free time. This not unlike bamf 2.1, hence the versioning. It is 2.10.605.1, Sense 2.1, with some Sense 3.0 elements from seo in the ADR version.
Screenshots
Features
  • 2.10.605.1 base
  • Deodexed
  • Zipaligned
  • Debloated
  • Busybox w/ proper dns support for ping and wget, credit to mrbawb
  • Sysro and Sysrw scripts
  • Sense 3 weather, and lockscreen elements (ADR)
  • HTC trace keyboard (ADR)
  • Stock kernel, with adb root and init.d support
  • Wake on volume keys
  • No recent apps bar
  • No GPS reticle
  • CRT animations
  • Menu overglow
  • 4-in-1 reboot options
  • Google Car Home
  • Google Docs
  • Teeter
  • Skins from Gadget! and Berzerker
  • More that I've probably forgotten
Patch 1
  • Fixes lockscreen strings for pin, password, pattern unlock(ADR)
  • Fixes force close in app drawer when sliding tabs at the bottom(ADR)
2.11.605.0 Patch (2.3)
  • Updates from 2.10.605.1 to 2.11.605.0 and in turn, to BAMF 2.3.
2.4
  • Toolkit is now included. Note if you have Sense 3.0 options, its old uber stuff. Remove the Sense 3.0 stuff from /sdcard/bamf_extras folder. Also, use wake on volume option in toolkit AT YOUR OWN RISK. It may cause your power options to hot reboot. I am looking into it.
  • CRT Animations are no longer included, to save battery. They can be re-enabled with this mod
http://rootzwiki.com/showthread.php?3369-MOD-CRT-Animations-for-2.10.605.1
2.4.1
  • Sense 3 phone answer screen is now present and working well.
  • Working google talk and camera, thanks to mystery dude (and Snow2 for finding). I also added additional libs from Dinc2 2.3.4 RUU.
  • Toolkit no longer breaks reboot menu and power button. Please delete Bamf_Extras folder from sdcard before installing.
  • THis is what 2.4 should have been all along. Sorry about that.
How to Install
  • Download ROM
  • Verify correct MD5 hash with your preferred verification app. Hashtab is a good one
  • Put the ROM on your sd card
  • reboot to clockwork recovery, either through hboot, or the command adb reboot recovery
  • Install from zip in recovery
  • Make sure you wipe data/factory reset. Super, duper recommended
  • Reboot, enjoy.
Download ADR Edition
2.2 URL: http://www.multiupload.com/7C905HLQ80
MD5: B4CC16072FCE449707A5FE7850AFC180
Patch 1 URL: http://www.multiupload.com/VL45A2CBL3
2.11.605.0 Patch (includes Patch 1)http://www.multiupload.com/MCWVDFL9B8
2.4 URL: http://www.multiupload.com/OPXSXASKWN
MD5: 472747F949C0DCDE42E9B98E89473550
Mail patch for those with fcs: http://www.multiupload.com/VNMURIC800
2.4.1 URL: http://www.multiupload.com/UJSR4FQUJY
MD5: F3FCA7E95208B374C9155CF971EB8A67
Download normal Edition
2.2 URL: http://www.multiupload.com/YWVD8T8FDZ
MD5: 8BF9421FD21F093C71A3FE4F8DD6DB48
2.11.605.0 Patch http://www.multiupload.com/HI7Z4PQX2K
2.4 URL: http://www.multiupload.com/ZJFHSMK628
MD5: A60B5F7E30A6EFD5166496B43FCAB24B [/CENTER]
2.4.1 URL: http://www.multiupload.com/EA5YLLWJ43
MD5: 51590F6B50E0AA5212B853816A2CC009
Re: [ROM]BAMF 2.2|2.10.605.1| (Side Project)
Wow that was quick! I really wish you had some more free time on your hands ;)
Thanks again for all the work you do, and for posting this here yourself.
Awesome. I love BAMF 2.1 and was hoping you would release the same ROM with the new base.
Is there any way to pull the toolkit out of 2.1 and install into it
I'll be downloading this, as it looks SWEET.
Question. I'm coming from Liquid Gingersense 1.6. Will I need to flash a radio?
Thanks!
First post has the rom's first patch (ADR version).
Adrynaylyne, the url for the patch is the same as the normal edition
Do you recommend a wipe for the patch? What is fixed/changed in it?
jochu
