[ROM] Carbonite Fusion G v1.0 ***2.3.3 leak base*** (UPDATED 5/24/11)
Well I reinstalled everything again and it works good. If it happens again I will try the fix permissions trick.
Thanks!!
Did it again when I rebooted. Is there a lower version of Clockwork recovery mod I should be using? I was on 00.5 and it started acting up when I updated to 00.8.
I'm still loving this ROM! I really like the screen animations. So smooth and lag free it's not even funny!
Yeah im also having an issue with both Wi-Fi and W-fi tethering....Im using "wireless Tether"...it worked fine when i was using Skyraider...it keeps asking me if im Rooted..
And Wi-fi doesnt work at all
So. I decided to give this ROM a try today... So far so good... I have one gripe. Why do I have to DL a wireless tether from the market? it's not a big deal, but just seems like it could have been included...
I really like the screen animations and carbonfiber look of this ROM... I am still setting it up the way I like, so i will continue to post issues (if I run into any)...
Great Job on the ROM trock and Great write up Pville :)
Reactions: PvilleComp
Make sure that under settings, you have Mobile Network checked off... it did the same thing to me until I checked the box... let me know if that helpd
Reactions: macneto
Just tried....no luck. and i have the most to date Wireless Tether app from the market. really odd to be honest never had an issue before. gonna try uninstalling it and then reinstalling it....
Yep that did it....it works fine now....had to uninstall it and reinstall it...odd tho never had to do that before...
Ok one problem down, one to go...Wi-fi still doesnt work. It scans but wont connect. even to an unsecured wireless connection. any thoughts you may have would be most welcome.
Thanks for the earlier tip
may be a dumb question, but did you try and restart your phone? and are you pressing the notification dropdown toggle wifi button or are you going into settings and wifi options that way.... also, perhaps try and go through the setup wizard again... its the upside down tophat in the app drawer. skip everything that you have already set up, but don't skip the wifi part of the setup... try and do it that way....... other than that.. I am at a loss for the moment... i will keep trying to figure this out for you. try both of those and let me know....
Reactions: macneto
Yeah i reset the phone a few times....i have also tried fixing the permissions....as well as going into the settings menu and enabling wi-fi that way as well...maybe ill redo the initial setup a little later on...thanks again dude!
ahh well not really a big deal. but thanks for the advice though.
I still like the ROM but my battery is worse with it than before I rooted. Going to have to try something else.
Been running a couple days now and you guys didn't lie. It is lightning fast. Love the screen animations as well. Great job developer!! Will rock this for a while.
Sent from my HTC Incredible using Tapatalk
The next update will be based on the new 2.3.3 leak. I'm not sure when it will be ready, But I am working on it.
Reactions: zero neck
Is anyone else having the issue that when you get a phone call, the phone will start ringing, but the display won't change to show the caller until about 3 seconds after the phone starts ringing?
Updated with 2.3.3 leak base. Remember this is beta but still stable enough to use. gtalk still does not work but I am working on it.
bosnium52
