[ROM][GB][WIP] CyanMobile Experience for the OV
Flashed and running
Love the new bootanimation and that it defaults to the ring style lock screen. Sd-ext options in development apply and stick. My wifi says error when I try to enable. I think it may have stoped when I checked the ed-ext options under development but I'm not sure.
My wifi works fine, glad its running good though :)
Sent from my One V using Android Central Forums
I'll test more and see if I can get more info on why... oh and SMS settings work as does calling
Something a little strange.. I can't use alternate keyboards it fails to enable them..
Oh joy XD. I'll try it in the morning and if it doesn't work I'll see what I can do
Wifi still won't connect comes up error :( using the last update
Are you using sd-ext? Wipe data, cache, dalvik, and sd-ext reboot and enable wifi before doing anything else
Not sure why sdext is causing WiFi errors..
Ok... Installed jaws latest kernel- lost wifi and now SwiftKey enables fine
I use bobzhomes kernel. I'll flash jawz later and see what comes of it.
Just stating my findings. Love the rom ics has nothing over this IMHO.
Edit: forgot to mention I can switch to system theme no problem and I'm using team carbons steel blue theme on it right now
Yeah I know, thanks for giving so much feedback and if you find more let me know. As for the theme, some people can change themes, some can't. For me it causes multiple systemui force closes, the status bar disappears and is impossible to get back without a reflash lol. That's why I don't recommend changing themes
@thewraith
Jawz kernel didn't break wifi for me
well now that is confusing.... thats definetly the last thing i did before i lost wifi and i flashed back to bobz 4v kernel and it came back... somehow i have now lost my status bar though... lol guess i'll be reflashing soon... by the way.. as a temp workaround i've set my swipe down function through adw to open notification bar and it works.
Lol great idea. I use launcher pro though
hey guys, you know that secret project I was always talking about? Fixed it. needs a couple of fix ups and ill release. It may take CNA's place, idk...
Cool! I'll check it out but If it's ics based I'll probably be back here on cyanmobile
jafar
