[ROM][GB][WIP] CyanMobile Experience for the OV
Hey sellers, told thou I'd being trying it this weekend. ;) first thought. SO MANY FEATURES. O-O my head almost exploded xD lol. I downloaded it this morning so that's basically at a first glance. I let you know my complete thoughts and experience by the end of this week. :D
Sent from my amazing OV.
You are going to need to go into more detail before I can help you.
Let's see. The text is the same color as the buttons in the play store so it's just one big blue button with no text (not really an issue but annoying Imo) status bar force closed almost immediately. Apps won't move either with the roms method or link2sd, performance settings won't stick, lots of reboots, dock auto hides even after changing its setting. I think there was more but I can think off hand
Reflash do a clean wipe and reflash
Sent from a humblebeast
I wiped multiple times before installing and flashed 3 separate times, each after clean wipes
I haven't experienced any of these other than the font color. For the status bar FC, did you change themes? If you did, thats your problem.
Playing with this more today, and according to store i ran out of internal space, however looking at everything I had plenty, wiped caches and dalvik, same prob
Can't see my ext, can't move to ext.
Clean flash and same prob.
Flashed another rom, and no problem with ext
Disappointed cause I really like the way this rom is set up
Really like the menus and the ics feel...blue ink in some places is kind of bothersome but I was getting use to it
Sent from my VM670 using Android Central Forums
I've just started using this ROM, however I have only experienced the color issue. Have you confirmed the MD5 to rule out any download issues? Sometimes the Recovery can cause problems. I am using cannabil v2.
Is anyone else having problems with recording video? My camera works fine but when I press stop recording in video mode it just freezes up,any ideas would be appreciated
Sent from my LG-VM670 using Xparent Blue Tapatalk 2
gee thanks lol it had fc both ways. With and without changing the theme. I have also gotten the theme to successfully change
You may be right, I'll re download, verify and try tomorrow
First Of all thanks for fixing mms! Great Rom, Ian still amazed by its customization :D but I would also like to confirm that the camcorder is not working :D I will replace the camera apk and report back! Really smooth rom!:D
Ok update: I took the camera. Apk from Gingersnap ported by thatguylurkin, I took the camera.apk from Gingersnap and placed it in system /apps of cyanMobile:D and set permission and rebooted, now I have a full working camera!:D
Reactions: sellers86
Report: music player don't work tried before my class fc ..I need my music :(
Wipe cache and delivc flash rom again and gapps too! If this does not work your going to have to do a complete wipe!! Because music player is working find for me :D I was listening to music last night like 6 hours!
Reactions: inceyet
It also works fine for me.... this ROM must be really temperamental.. camera will be fixed in next update
Has to be ....ugh this sensitive rom .. I figured as much ...and what about the sdext is there a fix for that as well...also has anyone flashed amphetamines with it if so yay or nay:thumbup::thumbdown:
Amphetamines wont hurt, though I think the scripts are already included. I haven't really looked at sdext yet, because I don't use it.
"sellers86" you stated that you don't use the "sdext" on your phone, so I'm curious, what do you use, or do, to get around the small internal storage problem on the LG OpV? I currently use Link2SD, & for some reason the sdext didnt work at first with this rom, but for past few days it has been working ok & mounting on boot for me, so I guess i'm just lucky so far
I have another question for everyone.....since I now have this terrific "Blue" themed rom on my phone, I have been looking for & have tested several, "Inverted GAPPS" from other forums & websites. Some of them say they work on our version android, but I have been unable to get any of them to load, or flash for me. The only app that ever works is the Market, but can't get any of the other gapps to install. Does anyone know of a set of the Inverted GAPPS, themed Black & Blue, that would work for this rom?
siacuz
