You would need to flash the bumblebee kernel. The recovery option is included in the kernel not the rom.
I just flashed Harmonia 1.2 with the newest Bumblebee kernel for kicks and I don't have the reboot/recovery options...
Sweet I was just coming on here to see if it was possible to add a boot into recovery/ reboot option when you press the power button.
^^ I haven't noticed any slowdowns or reboots, no memory holes either. My services screen shows the following for memory.
Other: 62MB in 6 Avail: 204MB+116MB in 20
Are you talking about Harmonia, or Harmonia with the Bumblebee files swapped in (which is what I was referring to). Harmonia itself runs great.
Harmonia 1.2 with the BB framework, etc files. There's a post somewhere in this thread that explained it, but I don't exactly know what I did. I was trying a lot of different things at the time. Is there any way for me to find out which files I changed? It runs fine and stable too.Are you talking about Harmonia, or Harmonia with the Bumblebee files swapped in (which is what I was referring to). Harmonia itself runs great.
There's an app called Quick Boot that I use -- if you've got LauncherPro, you can put it on the dock. It gives you the options you're looking for, just from an app rather than from the power button (and you can have it prompt before it reboots, to make sure you didn't hit the wrong option by mistake).
On a completely different issue...I'm running Harmonia 1.2 on both my phone and my wife's, and we're both running into a problem. It's quite probably unrelated to the ROM, but I'm wondering if someone else here has run into it. Recently we've both had problems installing apps from both the Google Market and from Amazon's app store. When I get an error, it's an invalid package file -- but often it appears to start a download that lasts for a few seconds (when I'd expect 10-20 seconds, at least), and then goes away with no installing message or error -- it's just done, without actually DOING anything. The app still shows up in the market as having an upgrade available, and I'm still running the old version. It happens particularly often with updates to existing apps -- new apps that have never been installed before are more likely to install just fine. Wiping the davlick cache doesn't seem to help often, though it might have helped once. Any ideas? Including ideas of where I should be posting this problem?
I had this problem as well yesterday. I ended up reflashing since I was playing at the time anyhow and messed soem things up.On a completely different issue...I'm running Harmonia 1.2 on both my phone and my wife's, and we're both running into a problem. It's quite probably unrelated to the ROM, but I'm wondering if someone else here has run into it. Recently we've both had problems installing apps from both the Google Market and from Amazon's app store. When I get an error, it's an invalid package file -- but often it appears to start a download that lasts for a few seconds (when I'd expect 10-20 seconds, at least), and then goes away with no installing message or error -- it's just done, without actually DOING anything. The app still shows up in the market as having an upgrade available, and I'm still running the old version. It happens particularly often with updates to existing apps -- new apps that have never been installed before are more likely to install just fine. Wiping the davlick cache doesn't seem to help often, though it might have helped once. Any ideas? Including ideas of where I should be posting this problem?
I've had the same problem for a while too, but it seems to appear on any rom I try. I've had the market issues for weeks on both harmonia 1.2 and bumblebee, so i don't think its specific to harmonia. I've wondered if it was because of titanium backup, I only restore the apps and never the system data. New apps usually install from the market without issue, but upgrading apps on the market seems to cause issues, either an unfinished download, an install error, or worse, causes me phone to reset.
Might want to try MyBackup Root instead of Titanium Backup. I installed the bumblebee ROM yesterday and MyBackup Root successfully reinstalled ALL of my apps, and their associated data, with NO problems. All market links worked as usual. Good luck!
when can we expect an update?
Well, I've switched to Harmonia 1.2 from AOSP.... and I like Harmonia much better because Bluetooth and Camera are still functional.
One thing I do miss, however, is the quick access to settings via the pull-down notification bar. In AOSP's CM7 mod, there were toggles for WiFi, Bluetooth, GPS, Brightness, etc.
Is there any app that I can install that does this?
Thanks!
Yeah I kind of thought of that before, but I don't think mybackup has a "restore to original location" option, right? Titanium backup has that, so all the apps that I put on the sd card are restored to the sd card.
