[ROM][KANG][08/05/12]CM10 Release Canidiate 1
Status
Not open for further replies.
Re: [ROM][KANG][08/05/12]CM10 Release Canidiate 1.2
evrything running smooth im still missing the camera?
all settings work great tho
super quick
Still no camera.. testing SU
Edit.. superuser working fine
super quick
Maybe the permissions just need adjusting.. :confused:
Ok so Im confused here is it the EG31 of FG31 modem that's the later one? :confused::confused:
FG31 is newer.. maybe they just had typo
sj
Sent with my Epic 4G Touch on CM9-8/06 @ 128 dpi using Tap@Talk Pro v2.2.4
Reactions: Glt5000
Man o man its super solid on FF18. Using op gapps. 4g widget/toggle isn't working, I got phantom voicemail back..super buttery smooth its nuts! Testing further so far 3g and 4g no los and super quick
Sent from my SPH-D710 using Tapatalk 2
I'll hopefully install 1.2 tonight.
I'm on a temp ICS rom cause I'm in the middle of an important text convo and I need stable signal.
So far everyone is having no LoS issues with 1.2?
Dk I've been stalking this thread since day one and never thanked you so thanks to you and denfender!how's battery on 1.2
No LOS so far. Great work DK
I'm in my house which naturally has great 3/4g. So I can get a good feel and so far its solid. At first it did need time to settle on first boot loading market. after a reboot its had no hiccups since. I have a good feeling about this so far.
I got LoS within 5 min, I'll have to try again later when I can get a log
running release candidate 1.1 and its awesomne,but having issues sending text..but great work DK!!!!
SMS force closes if I try reply to a text. If I compose a new one it sends and then force closes. At first I blamed it on my restoring previous texts with Titanium Backup, but maybe it's ROM related instead.
Hold off on the TB to restore apps, always gave me issues when doing that DL it from the play store
Dk do you mind if i use your rom as a base for a miui/jb mix rom ?
Sent from my SPH-D710 using Android Central Forums
Status
IdkWhyIdid
