[ROM][KANG][08/05/12]CM10 Release Canidiate 1
Status
Not open for further replies.
hold off. update comin soon
Snap! You crazy! :p
Thank and thank you Sir.
p.s. My wife hates you haha. She's team iPhone and will never get the appeal of android. Her loss...
-Still running AOKP RC4 (ye ol' faithful) 200dpi- Flirting with Jellybean on the weekends-
I tried to install the camera app from previous versions and still got the camera error.
I wonder if taking the camera from a previous build would fix the non-functioning camera issue..
On the LOS tip, is there any settings (on rom dev side) that you specify the "strength" of the radio receptor? Is it possible that it got "reset" or decreased somehow? (If its even a possibility)
sj
Sent with my Epic 4G Touch on CM9-8/06 @ 128 dpi using Tap@Talk Pro v2.2.4
Reactions: sjsharksfan
I'm sure this has been posted before, but there definitely seems to be a direct link between LOS and Battery life. If i hit LOS, battery plummets. Once i reboot/airplane mode/whatever to fix LOS, battery evens out (and even goes back up in some cases!).
I'm running RC1.1 by the way (was waiting until camera was fixed to flash again)
Just to restate, I've had no LOS since this Morning 8am and that's boarding the Subway, walking around, and letting my phone sit while in a meeting.
I did have LOS yesterday, but once the rom and the kernel settles it gets better.
Things are running so well on 1.3 right now, I'm hesitant to change anything. The camera is the only thing I'm looking for :) Is it in 1.4?
Status
angelag5098
