[ROM][KANG][08/05/12]CM10 Release Canidiate 1
Status
Not open for further replies.
There are two camera apps in the drawer. One works, the other doesn't. The only things that aren't working so far is the messaging app, and system settings/app control.
Jellybean is SEXY.
Sent from my SPH-D710 using Android Central Forums
Re: [ROM][PORT][July 29, 2012]CyanogenMod 10 Alpha 1
Anyone that flashes this, make sure that the ROM is saved on your microSD.
I flashed a JB Build from a different dev from my microSD and it worked, When I flashed again, this time from my internal memory, my device was bricked.
I've posted this information on XDA along with the exact process that I went through when the brick happened.
Recovery was CWM6 but I don't believe that has anything to do with it, as I used CWM6 on the first successful flash.
Only difference was the ROM .zip location.
I flashed from cwm5. At the moment, 4g and GPS are a no go. Screen resolution is a little strange. All in all, for a pre-alpha though, this is pretty amazing.
Reactions: Dark_Knight2
Ok 4G and GPS are borked....anyone else confirm this?
Incoming messages can be read and replied to. The app can also be opened from the gallery as a work-around. The messaging app just can't be launched directly.
Did you flash with EL26/EL29???
For the messaging if you go to /system/app/ amd rename messaging.apk to say messaging.bak and reboot the mms app than seems to work
Not sure if it has been mentioned but google search or anything related just force closes. Every few minutes a "unfortunately google search has stopped" message pops up. I'm assuming freezing the google search app will clear that up.
Wifi works.
Wifi works.
Try fixing permissions inside rom mgr.
I was able to flash the ROM successfully using Chris41g's TWRP recovery. Impressive work Dark Knight we all appreciate it. Some issues I've ran into
A lot of Settings cause an FC
Voice Search causes an FC
Cyanogen Settings cause FCs (was expecting that)
There's 2 Camera apps but only the second one works
Not trying to be an ass only trying to help. Thanks for sacrificing your time to get this ROM running!
Love how this is making so much progress! I hear that Sbrissen may be on board, if this is true we are definitely in for a treat!
sbrissen built the original kernel that got JB booting.. from what I understand.
yea lots of progress and exciting things happening now.
I am using sbrissens kernel in this port. All credit goes to him on that :)
Sbrissens handy work is amazing I must say.
Thank you for this info. This is a alpha 1. Duh. :thumbup::p:beer:
Reactions: patrao_n
Status
websitedesig102
