[ROM][KANG][08/05/12]CM10 Release Canidiate 1
Status
Not open for further replies.
Anyone else can confirm the zip edit isn't working? Maybe it was something I did?
Sent from my SPH-D710 using Tapatalk 2
Re: [ROM][Jellybean][07/31/12]CyanogenMod 10 [Beta 2]
this is so awesome thanks! :D i flashed over and for some weird reason my 3g is not getting a good signal it goes straight to 1x :/ and it freezes when i try to record a video on camcorder but other than those things it looks awesome so far! :D
Interesting what did you use to transfer the zip?
Can you register with Google now?
That updater script is from my beta 2. And beta 2 flashs without issue. Makes no sense at all
Without issue it flashes, but will not accept edits that I have made that have worked on every single build you have released....
So any word on B3? I really don't wanna go back to ICS, but the screen waking up by itself and weak signals are killing my battery too fast. This is still a great step in the right direction and I thank you DK!!
The screen keeps randomly coming back on.. anything for that ?
Seemed like he going to release a stable version but there is something wrong with the updater script and it is giving everyone errors while trying to flash so he pulled the link for the time being.
Heya Bloom what do you use for logcats? every app i use from market isn't recording
windows 8 , good old fashioned adb shell. You have to download android sdk, but it is flawless. Find a tutorial online, when I started doing this I used 5-6 different ones.
1. download android sdk
2. Install it to C:\ Android ( make directory)
3. update and install everything it says that is not installed for 4.1
4. Go into cmd (windows r type cmd)
5. Change directory to C: Android then change to platform-tools
6. type adb shell (edit make sure your phone is plugged in! and developer debugging is turned on :) )
7.type logcat -c
8. type logcat
9. when done logging hit ctrl+c and exit out of cmd.
10. open cmd again and type this adb logcat -d > logcat.txt
11. the logcat should be in your user directory
12. profit!
**Note it should not matter what version of windows you are running, if you are on mac, on linux the steps are different for terminal.
Reactions: sosovoo
Ive got the worlds biggest migrane trying to figure this issue out. There was super massive changes made to create a symlinking issue. In fact ive never heard of a recovery installing a rom then giving the 7 error. :banghead::mad::banghead:
That is what I was experiencing last night, went to bed with it and lasted all day until now... Just finally passed. This android stuff is very frustrating. But think about this, you were in WIP 3 days ago, now you are just about ready to declare stable! That is something, dev or not has ever done. They were in alpha for months on ics. This is crazy man, and you are doing it without actually testing it on your own device.
Status
popsicle
