[ROM][KANG][08/05/12]CM10 Release Canidiate 1
Status
Not open for further replies.
Re: [ROM][JB][08/03/12]CyanogenMod 10 [Beta 4]
Would like to know how your getting that for me it drained completely in 6 hour over night without using it
I dunno really. I've got it underclocked to 800, don't notice much of a performance decrease. Most time is spent in deep sleep (aka nothing has it wake locked) so that's good. Unfortunately a lot of time is spent in 200 because the screen keeps waking up and taking it out of sleep.
I like those odd *increases* in battery...lol wtf. o_0
Hey, really great work on this, have been following since alpha. One of the things thats keeping me from flashing is not knowing whether or not haptic/vibrate fully works. I know that when aokp betas first came out, haptic/vibrate was terrible and I was just wondering if the same thing is happening in these betas, since no one has really commented on it.
I've read that it worked just fine for some people, but others including myself had a very faint vibration. I guess there's one way to find out! :-D
Reactions: paulwong001
Well just tried bluetooth audio streaming in my vdub with no success. If I am not mistaken I believe I read that this a jb issue. Hopefully in future beta builds this can be addressed. Been unplugged for about an hour and battery percentage dropped from 100 to 80. Either than those small issues, this is a successful build from source.
Im also wondering if the SG3 has CM10 as well since I will probably buy one in a month.
Okay, so far no LOS
Beta 4; however, the build does say release keys. I'm confident I flashed the correct one.
I flashed lowriders gapps 4.1.1. Maybe people are flashing the previous version, 4.1.0
Modem FG20.
All the GAPPS are working.
If you need anymore details do ask. I'll be traveling later today, and I'll be able to report on the transfer between towers.
Also, I strangely have the option of AOKP wallpapers.
Google Now works flawlessly. So I'm confident it's Jellybean. Also about phone says Jellybean
I also had the CM9 boot animation...
Root works with DK Apps. The problem is for some reason SU does not prompt for root access. Go into the Super User Application, then click the wrench for Settings. Now, go to Security and click "Automatic Response". Choose "Allow".
The phone will now automatically allow all SU requests. Again, the issue is that SU was not prompting to grant access. NOT that root is broken on B4 with DKApps.
This solved the root access "problem" for me. Thanks!
One other problem solved for me that others had: Gallery was not fully working with DK apps for me (not syncing with Picasa, settings were blank). Installed Lowrider apps and all is working there. (goo.im was down yesterday some so couldn't try before)
Well has been working good but now day two on beta four and I'm getting los.
Sent from my SPH-D710 using Xparent SkyBlue Tapatalk 2
My screen turns on all the time, even without touching the phone, I put it on my desk, and a few minutes later, the screen turns on. I press the power button to turn it of, and a few seconds later, on again. Thoughts?
Thanks for the great job!
Click to view quoted image
what. 8 hours with wifi onnn? and not past even 70%? what are you running on your phone ಠ_ಠ
Well after exactly 2 hours battery was completely drained. Now that my phone is dead, I decided to add this comment to the thread. I am at work and live about 100 meters from the the sprint and clearwire towers so bad signal didnt kill it. At this rate, I will probably go back to CM9 alpha 6.
Hopefully future beta releases will have battery life and bluetooth audio streaming fixed.
Wait...
First off, why is this not mentioned on the Epic Touch CM website? Are you a completely separate group than those people?
I currently have CM9a6 installed. You say I can't flash this from an ICS-based recovery. What would be the best way for me to flash this, then? You mention EL26... But I'm on FF18, right?
i have 3g but my phone doesnt work. it gets stuck at dialing and then when you hang up, it just says hanging up but never does..
Wait...
Just use the CMW5 from the CM9 Epic 4g touch site. If I am mistaken someone can correct, but that is what I did yesterday from alpha 6.
Cyanogenmod Epic Touch: Tools
Then install once you are inside cmw5. I was just on alpha 6 until yesterday when i decided to flash this. It is a very good rom, but battery life for me was about 2 hours.
And I got LOS after about an hour
same here but after togling airplane mode on n off it goes back n i have service for anouther hours
unlike other builds u had to reboot
and the dialpad gets stuck
camera doesnt have much options just
shutter on/off
and 3mega pic
but i installed ics camera from market and i have a bunch of options
save to sdcard ... silent mode. and so on
i also wanted to know
there is this messaging app idk if its from jb or ics but its stock and i cant seem to have the same one as i use to have when people would have it in stock cm9
OK well I rebooted to end the call when it froze at call ended and that fixed it. Now I can send and receive calls and hang up with no problem
Sent from my SPH-D710 using Android Central Forums
I flashed everything accordingly, yet I've got zero 3g goin on, right from the start. Wifi works fine, I can text, call, but can't connect via 3g. Just a FYI.... Besides that one issue, this rom seems perfect. Thank you for your hard work dk.
How are all these results so scattered? What are you people doing during installation, because everything (except gallery and battery life) works really well.
Sent from my SPH-D710 using Tapatalk 2
Reactions: nothingblooms
ok so i got root now with dk gapps witht the fix a few post back but im losing 3g and cant make calls again urgh! everything was working but root last night its weird.
Status
gbTopaz
