[ROM] [MikRoms] Incredibly Re-Engineered Z v1.0.1 [03-8-11] Zzz..Zzz.Zzz ZOOM!
Thanks ill try it maybe I wasn't waiting long enough and I thought I froze so ill give it 10 minutes
Sent from my Droid Incredible using Tapatalk
Jardshoes, I did at first, just make sure not to update anything from the marketplace before restoring your apps from mybackup or any other type of backup.
I still can't get this rom to work. I wipe everything, used different clockwork versions and 3.0.0.5 and 3.0.0.8 I can't past the white incredible screen WHY????
I've been running it for a day, and it has been super smooth. Hulu is not playing for some reason other than that no bugs (fingers crossed)! So far I'm loving it. I've tried CM7 and Warm Z also.
Maybe I got a bad download. But in pretty sure that's where u got them both. It says it loads fine but still don't. How long does it take to pass the white incredible screen?
It took about 10 min to boot to the lock screen when I did it the other day.
I'm new to flashing roms. Can you over clock any rom?
Sorry - should have multi quoted.
You can only overclock if the kernel supports it. However overclocking will use your battery up faster and run your chips hotter so over clock with caution.
anyone know how to get boot audio to work in this? tried boot_audio.mp3, android_audio.mp3, and VZW_Droid.mp3 but its a no go.
i finally got it to work i used the download links that you gave me pville thanks a bunch the file from your link was a few megabytes biger so i know it was a different download
but now i still have a problem i have cant enter any touchtone prompts on voicemail, 611, or anything..... this sucks i finally get the rom to work and still have an issue
Happy to help - Glad it's working.
Try clearing the cache in recovery 2 or 3 times and re-flash the ROM. I tried entering my code on VM with the 2.3.2 ROM and it worked fine.
Im wanting to try this rom,
My game plan is to try out this Sense 2.0 rom on the weekends when 100% stability is not a huge deal and then flash back to a 100% stable rom (IE: Redemption Rom or Skyraider) when I head out for work. Since I work on the road 4 days a week I need something stable with good battery life.
My Question is without (Internal Storage Mount (EMMC) working how do I do a nand backup of this rom so I can just flash form one back to the other?
Thanks
Ken
This isn't a very large deal but when I was using this Rom originally I was getting quadrant scores around 1500 and I switched to something else and wasn't happy. I related the Rom and now only getting a average of 1200 any ideas? Thanks for any input.
Thanks
Ken
EMMC seems to be working fine with me.. I've been using this ROM for about 3 weeks now and the battery life isnt bad either its not to buggy as well
How do you use the spare parts add-on features? When I check an item it says downloaded but I don't see anything apply. I was trying to use the trackball wake feature.
Trackball wake is a hit or miss operation on the DInc. It's a limitation of the hardware., It may be working, you may just need to hit it a few times.
Reactions: bellison41
tejashviyadav
