[ROM] [PORT] LiGux
Are you using the one from the OP? Because I'm 99.8% sure the OP doesn't have Phone or MMS.
using the 6.14,12 port and everything works perfectly...except hotspot :/
for what its worth...my filename is LiGuxCNoob-Port-6-14-12.zip
i just did a complete reflash of this rom...just to prove everything works :)
edit: phone calls work...incoming and outgoing. sms works...incoming and outgoing. mms works...incoming and outgoing (the only issue here is that when you click on the pic message to view, you get a force close). wifi works. hotspot turns on and you can see it, but it won't connect. camera and camcorder works
Good your using the right one :D
@ mcclain71
Thanks for the update! This is using the LiguxCnoob port:D
@ ThatGuyLurkin you should start a new thread with most off your ports, since it would be less confusing! Just a thought :D
You got some really nice ports out there!! Umm i wonder what your workinh on now???:p
i really like this rom. the mms issue i quoted was weird, as i did a restore of a backup i did...and the mms works perfectly. lol. the only downside for me is the hotspot :/ i tried a hotspot widget and others, and it just wont work for me
Yea thats the only thing not working :( maybe he will update it when he finds out what the problem is!
DANG, You guys went to work! xD
Anyway what you guys do not know is that I'm a n00b when it comes to porting. I switched to the HTC EVO V but I am glad everyone worked on this. ALL CREDIT TO YOU GUYS FOR KEEPING THIS ALIVE!
If you guys want to make a new thread all the power to you! :D
Good to see you around!!:D
ThatGuyLurkin make a new thread, If this thing works besides wifi-hotspot it is extremely usable! Please make a new OP and lets get started :D!
Also, thank you BackHandLegend for letting the community take the credit/ROM from you!
Reactions: mcclain71
tabpro
