[Rom] Redemptive rEVOlution 2.3 *UPDATE* 2-23-11 Inc - EVO Hybrid
Requirements
FULL wipe both data/cache and especially Dalvik-Cache this is Mandatory​
Is there something specific I have to do to wipe this "Dalvik - cache" or will it wipe automatically when I wipe all data/cache before flashing the rom (so far I've only used ROM manager to install ROMs from the SD card).
Which kernel will really optimize my battery life? I'm not so much worried about a super fast phone, I just want my battery to last 12-14 hours under "normal" use. I am using Hydra undervolt and it's been great, but I don't think it's meant to work with this ROM.
Thanks!!
i decided to root again. this was my favorite (1.9) but this rom isnt the same. the old redemptive revo used to "flip" pages. but this one does not and there isnt anything in the "redemptive" folder. am i doin something wrong? is it because im flashing the update and not the full rom?
*edit* same thing Firstbeat asked, but no one answered him.....
New to rooting... just installed this tonight... awesome!
Couple of questions:
1. How do I get the notification pull down to not be transparent? I don't like the transparent part. Is there a way to mod this back or is that too difficult for a newbie?
2. Is there a way to change the color of the battery indicator to green? Same as above... if too difficult I can live with it.
Thanks!
Loaded this Rom last night and enjoy it. Many thanks to Lou. I don't know you but your work speaks for itself. The only problem I had is that cmw 3.x.x does not like it "installation aborted". Had to flash back to 2.5. After that all was well.
This is my first droid and I think I have made a good choice for my first rom. I see you have included a kernel pack. Any one in particular for good balance of speed and battery life?
It took me almost 4yrs to drop my iphone and I don't plan on looking back!
Again, thanks for a great build.
Read his recommendation. I am trying it now. Thanks for the reply.
I have also read that he fixed the problem with cwm 3.x in a maintenance release. Did not try the release but did grab the kernels out of it.
Wow! Great Job! thanks to HeyItsLou, I find this Rom a step up compared to other fantastics Dinc Roms out there, its the most smooth Rom ever tried till today and I being used the best of the best Stable Roms like SkyRaider 3.5, Incredibly Re-Engineered v2.3.1 , MIUI, CyanogenMod V7.0.0-RC1 , and many other and Wow this Rom is very very very good! thank you so much for all your hard work.
Having trouble syncing contacts with gmail. Contacts will sync down: Gmail > phone but will not sync up phone > gmail.
Anyone else having this problem? I have tried searching but no mention of this here or xda.
EDIT: I am an idiot and now have it working. Classic newbie user error. Sorry if I wasted anyone's time.
Love this ROM however does anyone have the Incredible's FM Radio apk? I have to listen to the FM radio while at school. Can't seem to find one online
Thanks
marik999
