ARCHIVED: [ROM] RodimusROM v1.2.3 + xionia [4/3/11] All themes update
Status
Not open for further replies.
I think the tests showed that 3g was better when you weren't transmitting data, but in the end, wifi is best for moderate data usage.
The developer bricked his phone. So development on this rom has stalled for now. I still use it but I am using one of the new kernels that has been made from LG source code.
Can you post a link to this new rom with the new LG kernels?
Thanks
Is there an easy way to flash a new kernel over a new ROM using ROMtools? Sorry...newbie here! :)
NM: Just figured it out!
Thanks for the heads up. That's how I did it last night using ROMtools. :) I'm running Rodimus with the Xionia 014 kernel now. It seems much better than the VM and 005 I was running until yesterday.
hey after you get a phone, could you work on a kernel that supports under/overvolting? the optimus v could use one....
How do I get the quick settings on the homescreen for wifi, bluetooth, brightness, etc...as pictured in the black and blue theme example?
Sorry, i'm pretty new to roms
It's actually a built in widget for Froyo. Just press and hold on the home screen. Choose Widget, then power control.
Hey if anyone can help me... i followed the instructions posted on the first page and can get the regular 1.2.3 rom to boot fine but when i go to flash the theme the status bar icons change but the wall paper, and other things in the posted picture do not is there a step i'm missing? Any help is appreciated.
What steps did you use to flash the original ROM and also the theme?
1. made a recovery
2. put the ROM on my SD card
3. rebooted into recovery
4. flashed rhodimus 1.2.3
5. rebooted
6. put the black and blue theme on my SD card then rebooted back into recovery
7. Flashed the theme and rebooted
1. made a recovery
5. rebooted
What recovery are you using, and did you wipe everything before you flashed the ROM?
Status
r3dpuk3
