ARCHIVED: [ROM] RodimusROM v1.2.3 + xionia [4/3/11] All themes update
Status
Not open for further replies.
Thinkin of trying this, is there any advantage over revolutionred's rom besides the theme and adblocker? Just curious, because currently I'm using red's and my battery life is amazin. Will try either way. Thanks.
You should read through the changelog. His is stock but Rodimus has tons of optimizations.
I did. Thanks, will be tryin this soon. I was only askin because previously when I used themes with battery % in status bar, it tended to drain battery a little more quicker than stock. If this isn't an issue, than this will most definitely be my new rom.
The % is only an xml edit to allow more battery images. It will not cause a greater batery drain than not having it :)
Flashed it with your exact instructions, 3g is on but not working. I'll try wiping everythin including system before flashing the rom, than I won't wipe anythin for the theme. I'll update this when I'm done. First thing I did was adb uninstall facebook lol. Phone seems to be insanely hot with first boot, but it could be a glitch, we'll see. Runnin smooth though, more so than what I had.
Edit: 3g working after I wiped everythin, including system before I flashed the rom. Bigger problem now though, wi-fi doesn't work. I just get an "error" when I click it. Reverting to backup for now.
I also followed your exact instructions:
I'm getting the message "error" when I try to Turn on my Wi-Fi. 3G kills battery life so I need the Wi-Fi
I love the theme, Wifi issue is a big problem but im sure it will be fixed soon. Keep up the good work.
yeah im getting the same thing with the back button and it seems that the signal has gone to crap
I have full bars, I think its a great ROM! And thanks for creating it! I'll just wait to see if the WIFI gets fixed!
Nvm links are updated. Assuming theme wasn't the issue than. Will try thanks
Sent from my VM670 using Tapatalk
Status
carlgrims
